Common upgrade...
I have only been on this web-site for a couple of years but there is no topic more discussed. Ok, maybe leaks get more attention. But "has anyone else done this?", I think everyone has done this(or had it done). So you should get lots of advice on this.Do you have the boat's wiring diagram? You can see a not very good one at:http://people.ne.mediaone.net/tlyons/tdl/hunter/index.htmlMy own solution doesn't agree with most of what you can read in the Forum Archives. Everyone seems to like golf cart 6-volt batteries or the newer AGMs. I replaced a wet-cell that was the starter battery with a gel. I have three batteries and they are the same make and rating, all gels. My charger(and alternator) are connected to the starter battery. The two house batteries are isolated(switch #2). But I have a "combiner", a device that senses when the starter battery has reached full charge. The combiner completes a circuit so that the charger/alternator is then charging the house batteries. I have no problems starting my Yanmar with a standard gel battery. Gels can be mounted anywhere, even upside down. They are maintenance free, stay on the boat all winter. Five months after I hauled her out I put her back in and the Yanmar started immediately
If you need more detail I could e-mail a sketch. Good luck. Ed(schencked@bfusa.com)
