Tom Wootton
Reading Don Casey's book on sailboat electrics, he describes a ground wire to the (inboard) engine block from the battery's negative terminal, thereby grounding the system through the propeller shaft to the water. Casey makes no mention of outboards. My outboard is connected to the battery's negative terminal through the negative lead from the electric starter/alternator. Does this ground the system through the motor to the water? If so, what about when the motor is tilted up? Am I not grounded? I keep the motor tilted up when sailing and in the slip; does this pose any dangers? Thanks in advanceTom
