Randy Conkling
I am concerned with lightning protection on my recently purchased 1995 H26 (water ballast). There does not appear to be any electrical bonding system on the boat. I purchased a Lightning Master dissipation system to install on the boat. For the dissipator to work, it must be bonded to the boats grounding system. What is the easiest way to connect my new dissipator to true ground. If the boat had a conductive keel, then grounding to one of the bolts would work, but with a nonconductive center board how to I insure good electrical contact with the water (ground). I have seen grounding plates advertised in sailing catalogs. How do you install these and would this be a good solution to my problem.
