I am needing to check the terminal block I am told exists in my step mast to which my apparent wind meter is connect. Both direction and speed stopped working following a recent heavy storm where I noted water leaking down the mast. I've had the head checked out and now suspect a bad connection at the foot of the mast. Is it possible to remove one of the step mast boards with the mast in place? I have removed the screws for the board in the head (forward) and then stopped realizing the mast bolts may go in to all four boards or perhaps the board I chose. Any help will be greatly appreciated.
