We have well kept 2014 Hunter 426 with a strange electrical issue. The boat has a Freedom 25 batt charger, and a separate inverter, a Panda Genset, and two AC units. As far as I can tell no changes or alterations have been made or added since it left the factory. The issue is when I turn off the two master battery (start and house) switches and have a 110 volt AC power on # 1 line coming into the boat I have some 12 volt power at the 12 volt panel. If I turn off # 1 and use only # 2 incoming A/C power it does bring power into the 12 volt panel.
I am speculating that the batt charge must feed off of the #1 A/C 110 volt power before the battery switch and this accounts for the back feed. There is no battery charger circuit breaker on the 110 volt panel which I also find odd. The back feed amperage seems low as I can hear the 12 volt fans increase speed when I turn the battery switch back on.
Is this normal to have this back feed? Has anyone else seen this and it an issue to be concerned?
Also, some of the wiring Hunter apparently used looks more like welding cable instead of heavy duty marine 12 volt battery cables. Does anyone else have a similar issue/concern?
