electric wiring
john withrow
Awhile back someone said there were electrical conduits running through the top and bulkheads on the h26. Where and how are these located and accessed?
C
Crazy Dave Condon
which year is your boat?
what year so a bettere response. Meow Meow from Crazy old fart head Condom
C
Crazy Dave Condon
NO there aint on this one
There are none on the old style 26. Running wiring through the headliner was a pain and it took some tall thinking. There are no conduits in this rascal. If you need help, call Gregg at Hunter and he will give you my phone. He does monitor this site and will know when you call. Crazy Dave Condon
C
Carl
Wiring Conduit
John, I have a Hunter 26 1994 and have had this same problem. I did find a blue conduit in the head liner but it stopped short of the winch inspection plate and didn't quite make it to the compression post. The previous owner had cut a three inch hole behind the compression post. I fished around awhile and found it but couldn't get a wire or snake to come out the other end. So I just used a snake and put a loop of wire on one end. I feed it from the winch end and snagged it from the other end with the other side of the snakes hook. I now have a 3/4 electrical tube running from the compression post to both sides of the cabin next to the winch inspection plate. It takes a little while to do but once it's in it make life easier. Carl
