Electric Windlass Seized
14
Hunter H340 Cobb Island Maryland
Hello All,
Well for my first post is a question on something I broke!!! lol I think I did anyways.
This is with a Simpson Lawrence on a 2000 H340. Pulling my anchor yesterday morning everthing was going fine until I got to the chain. Don't know how it happened, but the chain got twisted and bound up. It took me holding the anchor up to release the tension then unwrapping the bind. Now the windlass is locked up. When I hit one of the switches I can hear the motor kick, but it still does not turn. Could it still be a fuse? The lock is off. I do not have a blow up map of it to break it down. Or should I? Any ideas?
Thank,
Jeremy
"Celebration"
Cobb Island, MD.
Oct 1, 2007
1,865
Sounds like maybe the chain stripper is bent and jammed the gypsy. Try loosening the drum to release the gypsy and try it.
Jul 10, 2004
16
Hunter 38 Port Clinton, Oh
This site has manuals for your windlass. www.pyacht.com/simpson-lawrence-windlasses.htm
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Not really clear from your description...
Are you hearing the motor kick or just the relay. If it's just the relay, on my boat I have the circuit breaker on the main electric panel, and then a separate lever type breaker under the nav table. If my lever breaker is tripped, which it will on an overload like you describe, I will get only a click when pressing up or down buttons. Hope this helps, because then your fix is just to find and reset the second breaker.
Ross
Jun 15, 2004
14,693
Re: Not really clear from your description...
Doesn't that thing have a socket for a winch handle? ? Try turning it by hand and see what the problem is.
Beneteau 323 Annapolis MD
Maybe the chain is backed up from down in the anchor locker and jammed the chain in the hole down to the locker???
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
My boat came new from Hunters with the main windlass motor connected to the engine start battery via a 75 amp thermal overload and the push buttons and the main up/down breaker wired to the house battery.
Thus the up/down breaker would operate with a loud click even though the main motor breaker was tripped.
Aug 1, 2011
14
Well thanks everyone. It was as Mulf said, however my 2nd breaker is in the Starboard Stern seat compartment with the battery charger and batteries not under the Nav. table. :dance:
