Jeremy, they are not ignoring your question,
it is just that there are not to many folks that have done that if any. Boat designers do not make allowances for the installation of windlasses in their smal sailboats as there is limited space, these units are power hungry and the weight of the anchors is light. Anything can be done, but the question is at what cost or tradeoff. The list may look like this;1) Modify and reinforce the bow deck of the boat. Add anchor roller.2) New rode with line spliced to chain.3) Electric windlass, heavy gauge wiring, solenoid, buss breaker, switches and enhanced battery recharging ability. Optional dedicated battery located in the bow.4) Tradeoff space in the V-berth to locate the rode locker and perhaps a dedicated battery. 5) Installation work of running wiring along the hull to location of batteries and to the switches at cockpit and deck.The components for the installation alone includting the windlass will run you close to $1,500, the labor is difficult especially the modifications to the bow area and perhaps the loss of use for the V-berth. All this for the benefit of lowering and raising perhaps a 25 pound anchor and perhaps 200 ft of rode. The cost to benefit ratio is ridiculously high. A much simpler alternative would be to install a manual windlass. If you must go electric consider installing a line only capstan winch with no rode locker. This winch would be tailed and operated from the foredeck. My suggestion would be don't do it.
