I bought my first sailboat, a Catalina 25 Swing Keel. As the title states, it has an electric winch. Pretty simple to operate. To bring up, I hold the toggle switch up till the winch sounds a beep, which I take it to mean it won't come up anymore. Then I back it off a couple inches because that makes sense to me.
My question is on lowering do I just keep going till the cable finally shows some slack, which is what I am doing?
And then do I want to the cable loose or should I have a little tension when the keel if fully extended?
Any advice on dealing with a swing keel would be welcomed. I also need to come up with a way to keep the water from sloshing back up. Was going to get all technical and get a bung from a barrel that would fit just right. But then I realize I could probably just put saran wrap around the opening.
Thanks.
Al
Thanks.
Al
