Electrics . . .
I get about 2-3 hours from a full size battery, (110 amp/hr) on my Sea Eagle 11 inflatable. The time depends upon how fast you go - and since these are not real fast, I use 4 or 5 on my 5 position throttle most of the time. I have a 44 lb MinnKota, it works well for the inflatable, but I have only ever used mine on very flat water.Many electrics are not salt water compatible, so check that out as well, if you are on the ocean.I have seen some folks using a jump starter battery - it works & is lighter and easier to carry, but probably has 1/4 to 1/3 the run time. Several folks moored at a local lake do it this way to get out to the mooring.Remember - even a 2hp outboard will outperform almost any electric. I think the equivalence is about 75 lbs thrust per HP.IMHO, An electric won't work at all well against much wind and chop.Hope this helps!
