Electric swing keel winch - Chrysler 26
Sep 22, 2019
118
Chrysler 26 Pymatuning Lake
Hi everyone,
I was wondering if anyone has seen a trailer sailor with an electric winch for the swing keel? I have a 78 Chrysler 26 with a 1000# swing keel and I thought it would be cool to install a 12V electric winch for the swing keel with cockpit controls. I was wondering if anyone had any experience with this kind of thing. I did a search and did not anything directly helpful.
My questions are recommendations for winch models, especially ones with a clutch so as not to break the cable!
Thanks!
I can see why you would want that. When you kiss the bottom and the wind is blowing hard, you don't really want to leave the helm and spend 10 minutes in the cabin cranking a winch handle but....a concern I would have raising the keel from the cockpit is ...
How do you know when it is all the way up. If you overwinch, you will bust your keel trunk and sink your boat. You would need to engineer some sort of fail safe into your system so that the winch stops before the keel is fully raised. I'm not sure what type of sensor you could use for that purpose but I would consider it an essential element of the design.
Likes: Sailor Sue
Sep 22, 2019
118
I am trying to find a model with a clutch of sorts that will allow slip when the keel is all the way up
Sep 24, 2018
3,992
Catalina 30 MKIII Chicago
We have a couple of electric hoists in the shop. There's a lever/hoop that's attached to a switch. When something hits it, the motor shuts off. You could potentially put something on the line to trip a switch or buzzer. I'd imagine line with a bit of stretch would be beneficial to reduce the potential for damage in this application. Pics of your setup would definitely help
May 24, 2004
7,202
CC 30 South Florida
If you raise the ballasted keel all the way, the boat will become unstable, if you do it with the sails up there is a good chance it could roll. They day when I would be physically unable to raise the anchor, trim the headsail or raise the keel in a 26' boat without power assistance it will be the day I quit sailing. It would be cooler, literally, to have the additional power to run the refrigerator.
this will seem glib but that sounds like you have never cruised in a swing keel… just sayin’
Mar 2, 2019
629
Oday 25 Milwaukee
Our first boat was a Catalina 22 with a 550 keel . I'm familiar with what you are trying to accomplish .I'd consider an ATV winch from
Harbor Freight . They ahve 12 volt winches with wireless remotes . It wouldn't be that hard to figure out when the keel is fully raised .
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
I have a hanger door that I lift with a harbor freight worm gear hand winch. It worked just fine but I got tired of lifting the door 10 feet off the ground and then cranking back down so I removed the hand crank from the axle that turns the worm gear and replaced it with a 7/8 hex nut. Then I got a cordless drill and a 7/8 socket to fit the nut. The drill is much faster than I am I didn't need to create some sort of limit switch to stop the quarter inch steel aircraft cable from breaking something. Just marked the cable so I know when to stop pulling the trigger. The original handle hangs right next to the winch assembly in case the battery gets discharged or the drill gets temporarily lost. When I do the same for the boat I will probably put a drill in a big baggy to avoid corrosion problems when it's not being used.
Likes: Timm R Oday25
