Electric propulsion thumbs up or down?
caguy
Sep 22, 2006
4,004
Has anyone installed one of thes electric motors? What is the cost? How is the performance and range?
http://www.electricyacht.com/
I have also been looking at some of the DIY projects. There is a group at Yahoo that has been around for a while.
How much solar do you need to recharge after 6 hrs of light motor sailing?
It seems there are a lot of options and variables concerning motors, batteries controlers, heat and cooling.
The other issue is that most are replacing an A4, my boat came with a OMC saildrive. Would I be better off convering to a shaft or adapting the sail drive unit? Is there added drag with the saildrive unit.
Just getting started on this.
olsalt
Nov 20, 2009
42
Oday 222 Oneida Lake in Upstate NY
The current issue of Good Old Boat has a nice article about an electric conversion. The author reminds us that its cleaner, not as smelly, safer and takes less space (more stowage!).
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
website
Woody...if you go to the Good Old Boat site they actually have most of the article up. Just in case you aren't a subscriber. The guys set up was cheap, at a couple of thousand, but it really seems underpowered for a boat that displacement. It was good for about 4 knots for three hours or so, if I recall correctly. I'd certainly consider doing it for something I was daysailing under 25 feet, but I don't think I'd do it for my 30 footer or if I intended to cruise. Of course I could put larger batteries in my bigger boat (his were relatively small).
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
If you are thinking about this, I suggest you search out all the recent threads on batteries. A set up like this is one in which you are going to either need a huge battery bank or be drawing your batteries way down. Battery management is going to be a challenge and battery life is apt to be very short. It may not be all that green by the time you factor in the lead and shipping the batteries over from China.
It's a very different situation with cars where regenerative breaking can put a lot of power back into the batteries. Hybrid cars would probably not exist if cars went uphill all the time which is essentially the propulsion profile of boats.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
For a smaller day sailer
For a smaller day sailer, the electric might be OK. But for a bigger boat, don't think this is a good idea. For any extended use, the battery bank would have to be huge, and expensive. The power output that works fine for getting into and away from a slip, probably isn't going to cut it if you get into a situation where wind/tide is against you. I keep thinking of some of the inlets on the gulf coast, and how I could possibly manage them with less power. When the tide is running usually am wanting more, even with the diesel.
Jan 4, 2010
1,037
Farr 30 San Francisco
The consensus seems to be that electric is a wonderful technology so long as you don't need to go anywhere. Suffers the same problems as the electric car, to whit limited range and slow recharge.
As far as the solar array for recharge, hmm 6 hrs of light motor sailing what size boat? call it 7kw (about 10hp) so you use 7x6 42kwh if that is 80% DOD on the battery pack then you have a 53kwh battery, dividing by 12 to get to amp hours works out to about 4000Ahr battery. Kind of large. Anyway we go forward, charge on 4000 Ahr pack maybe 10% of rating or 400A, so that works out to about a 5kW solar array for a 10hr charge, (not including night)
On the other hand I know somebody that has electric propulsion on his boat, powers out of the harbor about 1/2mi sails, powers back in, plugs in recharges, wonderful quiet solution for that use.
caguy
Sep 22, 2006
4,004
I agree that it may not be a good idea for larger boats but what about my Cat 27?
I regards to battery choices it is my understanding that they are getting better, but what type? Technologically, I usually run a generation or two behind, primarilly cost and the fact I'm do damn cheap (which is my main ''green'' issue.)
As far as replenishing batteries I wonder if the free wheeling prop could be used to generate electricity while under sail?
A big concern is the life of the batterie.
Jun 6, 2006
6,990
To answer the questions:
If you had a very large 400 watt solar panel it would be putting out 400/13.6=29.4 amps at peak sun. The bad thing is you get peak sun only about half an hour a day. Using the hourly profile (each hour has a different % of the peak sun output) starting with 0600 and going to 1800 hours (.1, .2, .45, .6, .75, .85, 1.0, .85, .75, .6, .45, .2, .1) you get 203 amp hours per sunny day. This is about the most you can ever expect without actively aiming the solar panel at the sun all day long. BTW you will surly almost never get that amount due to the panels being mounted on a boat and there will in almost all cases be shadows cast on the panels.
203 AH is about 1/2 of a 400 AH bank so you could recharge (not really but suspend disbelief for a second) a 400 AH bank discharged to 50% every day. That is a very healthy solar capability!
203 AH driving a motor would last as follows:
@ 10 amps 20.3 hours ---> 120 watt motor (yawn, most electric trolling motors are bigger)
@ 20 amps 10.2 hours ---> 240 watt motor = ~ 1/4 HP
@ 40 amps 5.1 hours --> 480 watt motor = ~ 1/2 HP
@ 80 amps 2.6 hours --> 960 watt motor = ~ 1 HP
You can see where the numbers are headed. The biggest solar panel I've ever seen was around 400 watts worth and they had them EVERYWHERE. They ran out of space for more panels. This is not much of a capability when you consider using it for powering a motor. And we have not even addressed battery acceptance which will only make the numbers worse.
Course you could use a small genset to charge the batts and have a slightly more efficient system but then all you are really doing is replacing the transmission with wires between the motor and the prop.
The real problem with electric propulsion is not that it is not doable it is the storage of enough power to allow you to return safely to port.
A sail drive has about the same drag as a shaft and prop.
Jun 6, 2006
6,990
Generating power from the prop spinning while the sails drive the boat is an option. However, there are some very significant losses using a fixed prop in the "wrong direction" With that said if you mostly sailed and only used the motor for minor docking maneuvers this could actually kill a couple of birds with one stone. The prop driven motor/generator could supply all your electrical power while under sail (cost is boat speed is reduced) and could charge the batts also. This would get you out of buying a wind generator or solar panels or running the engine to charge the batts. However when you are becalmed or at anchor you have NO charging capability....... so you still need some way to charge the batts as needed……. And you will not have a motor till you do!
Now if you had a “Mr. Fusion.” Why you could just put your table scraps in it and you could tear a…s around the Bay all day long. Might even become a “power boater” with that kind of “battery”
1.21 Gega watts is 1.5 billion HP BTW
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Electric or hybrid propulsion seems to be akin to religion around here, with believers, doubters and heretics. ;)
To declare my own bias up front, I happen to be a believer in hybrid (electric plus IC engine) powering. I don't necessarily think that the ideal solution is commercially available, but I do believe that all the right technical pieces are now available, and it's now down to trying and refining different combinations to find the most efficient and practical system, and have it produced in sufficient quantity to get the price down.
The hybrids you linked to, with an electric motor/generator coupled to the propshaft of a conventionally-powered boat, seem to me like the first iteration that could gain widespread adoption. It's not optimally efficient from an energy point of view, but it has the potential to bring the advantages of electric propulsion (strong torque, quick direction change - great for docking, reduced need for short-running a cold engine) while still retaining the reliability and efficiency of direct IC engine drive for long running. It requires only a modest increase in battery bank size, dependent on how many minutes of sustained electric running you want to have. For the casual sailor who can be on shorepower every night, and just has a short run to get clear of the marina, they might never need to start the combustion engine, except for sustained running (eg a weekend cruise).
Sadly, I haven't yet seen an off-the-shelf hybrid offering for saildrives, but I haven't looked much into that.
Disclaimer - I have some electrical engineering in my background and I'm a hopeless optimist. Also, our boat isn't a candidate for hybrid, unless I find a cheap electrical outboard or build my own.
Oct 2, 2006
1,517
Jboat J24 commack
Hunter has done it with the 27e and i dont know that is has or has not been a big seller
Alerion did a 33e and i do not believe it has gone beyond one hull as its cost was a good bit more than the standard diesel
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
Hunter has a 27' electric drive they were showing off at the Annapolis boat show last year. It has a massive solar array (about 8' x 8') over the bimini , and a wind generator.
I don't recall specifics, and I am not finding them on their website, but I think it was rated with a 10hp electric motor and the battery bank (with no sun or wind power generation to extend the charge) it would power the boat for about 6 hours at cruising speed, or 2 hours at full throttle. I believe they said the solar and wind combined should fully recharge the batteries from completely dead in about 1.5-2 days if I recall correctly.
btw, even the stove in the galley was electric on the demo
caguy
Sep 22, 2006
4,004
I keep my boat in mastup storage and have electricity available for recharging all week. I like to go to Catalina where it is mooring only and would need storage ti last 4 days andtrip home. I only motor sail when my speed drips below 2-3 kts. That is sometimes as long as 3 hrs with ob at 1/4 throttle.
I am headed over to http/:www.apexelectronic.com after work to see what he as in the way of motors. Being the son of an old junkie and engineer, this place is like a candy store for me. This is where I buy my tinned wire by the pound. Most of it is aerospace industry surplus. Check out their website it's amazing. The owner is pretty knowlegeable too.
BTW Pardon the typos, I am all thubs on this cell phone.
Nov 9, 2008
1,338
I have always dreamed of building an electric car, so naturally projected that into my sailing. So piture this. You're 16 km from home, about 3 hours of motoring due to the dead calm that just settled. But, you've been on the water for a couple of days, motoring in and out of those cute little coves that the Admiral find so romantic (I'm dreaming). Of the three hours of possible motoring on your battery bank, you've already used 2 hours. Would it be easier to:
A) Wave somebody down and request to raft up for a day or so while you recharge off their diesel?
B) Call SeaTow and have them meet you 1/3 of the way home
C) Pour another gallon in the ourboard.
When I can charge a battery the size of a coffee cup and motor for 12 hours, I'm on it. Or when I can screw another can of hydrogen onto the fuel cell, I'm all over that. Otherwise . . . . Besides, electric may be "cleaner" on the water, but there are still smog-belching, coal-burning power plants pulking carbon emissions into the air to fill refill the lead batteries your floating around. (unless they're glass mat or something).
I'm all for the Mr. Fusion thing Doc! Great Scott! What and idea. I mean it's really heavy if you think about it!
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Hey all, the concept is just that,a nice thing, but in a boat not really practical. As it was already stated, we are going uphill all the time in a boat, there is just too much drag in water, even plain still water. We in boats have power issues with things like lighting, cooking, everyday issues we are still trying to make better. Its one of the 3 main items a cruiser or sailor needs , water, power, food. I drive practical cars civics, accords, I have been recycling since the mid 70,s, I really am getting tired of the political machines using the word green, green,green, bull, look at ethanol/corn, I will not apoligize for using a little diesel, which by the way they are screwing me for anyway. just my 3 cents Red
Johnb
Hunter 37-cutter Richmond CA
Yep - a pound of diesel burned at 30% efficiency represents as much energy as you can store in about 120 pounds of batteries.
If you really want to save, drive a more efficient vehicle to the marina.
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
My Catalina 250 WK got caught in a squall in the Charleston, SC harbor last Thursday afternoon. Being way overpowered my crewman and I should have dropped the mainsail, partially furled the genoa and started the outboard engine. If that wasn't enough to at least prevent losing ground downwind then we should have completely furled the genoa, dropped the anchor, and gone in the cabin to warm up. What we did was drop both sails and rely on the outboard. The 9.8 hp outboard wasn't enough to prevent losing ground due to hobby horsing and the resulting propeller cavitation. I could not "tack" across the wind either. We did have enough control to duck into a somewhat protected lee shore marina after "jibing" to partially downwind. A weaker motor would have allowed us to be blown into the retired aircraft carrier Yorktown. It is permanently aground there.
If you want the equivalent of a 10 hp gas engine look at (expensive) 24 volt trolling motors or electric outboards with around 200 pounds thrust and several golf cart batteries. Golf cart batteries have solid plates. They are made for deep discharging. "Marine" batteries with their coarse grained plates are not tolerant of such treatment. See http://batteryuniversity.com/
BobM
Jun 10, 2004
3,269
My friends rented a hybrid (small diesel genset and twin electric motors with batteries) Catamaran down in the BVI. They hated it. In order to keep the batteries charged they said the gen set was running all the time, which was annoying and they claimed that they actually burned more diesel than they had the year before when they rented a conventional boat.
Nov 22, 2008
3,562
The physics would support that, in fact make it inevitable. There are losses anytime you convert from one form of energy to another and significant losses charging batteries. The engine driving a prop is going to be way more efficient than driving a generator, charging batteries, and then running an electric motor.
Absent huge solar panels or frequent plug ins, a "hybrid" has to burn a lot more diesel for the distance covered than a conventional drive.
Even diesel electric where the generator directly drives the electric motor has a significant fuel consumption penalty.
