I agree
I used a trolling motor to push my Daysailer for a while. Not even 1000 pounds fully loaded, and even a big trolling motor didn't cut it for long. The two problems I see are the battery issue, and the low speed these things operate at.Trolling motors are designed to push things very slowly, so they had relatively large props, with big pitches, turning pretty slowly. I put my trolling motor on my Zodiac and we go four knots. I put it on the Daysailer, and we still go four knots. The reason this is so is that neither boat is taxing the motor to the point that it cannot do the work. Without going in lots of detail, suffice to say that a trolling motor does its work with lots of grunt times low revs. An outboard on the other hand, does its work with relatively little grunt, but tons of revs - the result is that a higher top speed it possible, but the motor is much more sensitive to the load its pushing.In the end, the charging issue was getting to me, but not as much as only being able to go four knots into a five knot current.Justin - O'day Owners' Web
