I'm trying to figure out why the cabin lights on my H 30 aren't working. When looking at the back of the breaker panel are the ground wires supposed to be connected to the negative bus bar that runs down the negative side of the of the breakers? Are all of the ground wires (the black ones) supposed be attached to the stand alone bus bar which is then connected to the negative side of the breakers? Most of the ground wires go to the bus bar that is separate from the breakers by the PO seems to have attached a number of ground wires on top of the bus bar that runs across the negative side of the breakers. Is this correct?
Suggestions?
Suggestions?
