Dave Emery
I’m currently considering replacing my failing manual Jabsco head on my Catalina 34. I’ve been looking at Electric Macerating Heads IE: Jabsco Quiet Flush, Wilcox Crittenden Newport and Raritan Sea Era. My number one consideration is finding one that will fit on the preformed platform in the Catalina 34 head. I’ve measured the Newport and it appears that it will fit. I’m assuming if I can mount the motor on the Jabsco and Raritan to the right versus the back they will fit. I’m considering using raw water for flushing in order to conserve my onboard fresh water. I’m also considering ordering the remote pump option in order to make the head a little quieter. It appears the flush options are different on all three heads, Jabsco – wet, dry, or both, Newport – wet or dry only, and Sea Era wet dry combined only. Is this a consideration? Is my 27 gal holding tank sufficient for these heads? Does the remote pump option (using raw water) make a difference in the noise level or should I save the extra money and use the integral pump provided? Should I sacrifice fresh water for flushing (I currently don’t have head orders using sea water)? Any information regarding these heads or general information regarding this topic would be greatly appreciated.Thanks, Dave
