If there is an electric fuel pump between the tank and the Recor 120 fuel/water filter separator, and the diesel engine is running but there is water in the bottom of the see-thru bowl,can the drain off valve be cracked open to drain off without air being introduced, causing fuel starvation at the injectors? Bleeding my Yanmar 30GMF is not easy!thanks.
