For a 4 foot lift and a Yanmar 2GM20F engine, What Walbro electric fuel pump model do you recommend? The original was a Walbro WEP-12. Some have used a Walbro 6805, which is no longer made. We are about to replace the Racor 120 with a Racor 500 MA 10-micron fuel filter. There is strong evidence that previous owners have had air in the fuel issues (2 micron primary filter, outboard motor primer bulb at tank outlet (not USCG approved), stripped threads on bleed screw of secondary fuel filter, hose size too large for barb, failed electric fuel pumps, etc.). Both the fuel supply and return from the aft most injector have a high point of 4 feet from the bottom of the tank. I am thinking of replumbing the fuel hoses to eliminate the high point. The tank is 2 feet tall so the head or lift is 2 feet with a full tank. Fuel consumption is approx. 0.4 gph so the Racor 500 MA is over kill, but easy for filter changes with a pressure gauge on the pump's suction side. What is the maximum pressure for the low pressure side of the 2GM20F? I'm thinking of either the FRA 2 or FRA 20, but confused about running continuously (FRA 2) or when fuel is demanded (FRB 20). Thoughts? Thanks.
