Electric bilge pump setup on 1981 Hunter 25
K
KennyH
My Hunter 25 has no permanent bilge pump setup. With only two thru hulls, sink and cockpit drain fittings how have some of you done the manual/electric bilge pump setup. Where did you run the line overboard etc?
Sine Nomine
Bilging a Hunter 25
I have both a manual and an electric, the manual is bilged out the rear starboard side and the electric is bilged out the back between the two cockpit drains.
