C
Crazy Dave Condon
The other day, Jim Seamons called why sailiing to advise the stern rail was giving him an electrical charge while the motor was running. Jim has an electric start engine and according to him, he replace the wiring to the stern light. Jim per my advice did disconnect the electrical line from the boat and no more charge in the stern rail.Jim, when the motor is running and connected, you are charging the battery. In the wiring that you did, you must have connected the new wiring in such a way that is is hooked into the battery system whele the engine is running. Check you wiring for the stern light to make sure that you did not wire it up wrong and please advise what you find.Dave Condon
