ELCI breakers ??
Catalina 320 Dana Point
I will need to pass the marinas new electrical leakage test soon to move to a newly built slip. It appears I may need to add an ELCI breaker to the shorepower inlet to comply with new electrical code. What have others experienced with putting 20+ year old boat in new dockside electricals? Were you OK as built, or need the ELCI or have you had problems with an installed ELCI?
colemj
Jul 13, 2004
831
I can't answer the question about using new dockside electricals, but have installed an ELCI breaker. It is just as easy to install as any other breaker - existing 2 wires in, existing 2 wires out, done.
Last year, our original 2005 ELCI failed by not tripping when the test button was pushed. I replaced with this: https://www.amazon.com/dp/B0CXPMJGKL?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4&th=1
If you don't pass a leakage test, then the breaker isn't the issue. On the other hand, an ELCI breaker is a very good thing to have, and it doesn't cost much.
Mark
I upgraded to a new ELCI AC breaker panel and installed a galvanic isolator. No more problems.
Likes: Ward H
CYQK
Sep 11, 2009
595
beneteau first 42 kenora
Well......
I installed ELCI breakers on my boat
Yesterday there was a huge lightning strike to a boat a couple slips over
Breakers tripped think it saved my boat
Likes: Ward H
colemj
Jul 13, 2004
831
Well......
ELCI are not surge protectors. While it is possible the strike may have created a current imbalance on the L and N lines which caused it to trip, it also likely that a surge exceeded the breaker's rating and tripped it. If so, then you will want to carefully inspect all of your AC equipment for damage.
Mark
CYQK
Sep 11, 2009
595
Lucky for me i installed a 30amp surge protector as well on the shore power cord
Obviously it didnt blow the surge protector but there must have been something going on to trip the ELCI
Likes: Ward H
