Hello, I have a 1997 hunter 430 with a grunnert (sp) system. I dont have my manuals with me so I am not sure of the specifics. When I run the system the freezer will continue to drop in temperature but the refrigerator compartment will drop to the low 40 degree area and then rise back up to over 50 degrees while the system continues to run. When the freezer gets down to temperature if I leave the system on it will cycle on and off, sometimes every few seconds. On purchase a refrigeration service tech came out and we learned that the system will delay this on/off problem if both the fride and freezer are run at the same time but it still occurs after a few hours. I assume, perhaps in error, that the on and off is hard on the system so I tend to regulate temperature manually rather then with the thermostat but I would like to be able to just get the system cold and leave it on to self regulate by temperature. any suggestions?
