David Michaels
After a month of sailing with the tiller basically sweeping anyone in the (very small) cockpit out of the way while tacking/jibing/recovering from a nasty bit of weatherhelm, I'm considering setting up a rack and pinion quadrant and some sort of wheel, similar to many catboats. Has anyone out there done this on an H27? My traveller is mounted at the stern, I don't think this will be a major problem, as I don't think I'd be building any kind of seating arrangement over the quadrant. I find that to get good visability I have to sit on the rail or stand anyway so I'll have to devise some sort of risers port and stbd. to sit on while steering. Also, this '79 has a lazerette/icebox (depending on who's drawing you're looking at) and I'd hate to lose that much locker space. I figure I will build the cover so that I can still get partial access to this area, but this is a concern. Advice is welcome.If you have done this, how difficult was it to relocate the aux. controls? With the steering in place, the controls will be too far out of the way for close to the dock work (steering, throttle control, fwd/rev while docking, etc.). Have you noticed any difference in the boat's response, good or bad? I'm shoal draft as it is and sailing to windward is already a challenge, will it get worse with the quadrant?Is there any alternative to the Edson rack and pinion quadrant? It's a hair under $1000.00 w/o a wheel. It's probably about $1500.00 plus my labor (including building a cover) if I go with them. This is pretty pricey for me, but it would be nice not to have guests in the cockpit having to do gymnastics to avoid the sweeping tiller. Pedestal steering is about the same money from Edson, but I have not heard a lot of good things about pedestals on the older 27s. And I'd still have to move the controls.Is this a Bad Idea? And if so, what's the work-around for the "big tiller, small cockpit" challenge?
