I was trying to service the cables in my pedestal last weekend and found that I could not remove the four screws under my compass to access the throttle and shift cables. I have a 1984 Catalina 30 with an Edson pedestal. I was able to remove the compass with no problem but I could only remove one of the four screws holding the compass mounting section. The one screw was fairley long and only a standard flat head screw type. I soaked the three screws in everything available and nothing helped. I bought a new larger screw driver and used a wrench. I hand someone tap the screw driver as I put pressure. No movement except a small amount of flex in the screw itself. I am affraid of braking the pedistal and really having problems. Anyone have suggestions> Thanks.
