If you remove the compass, a serial number plate might be located on the inside of the pedestal near the steering gear. You can call Edison with the serial number and they can give you exact details. I replaced the radial drive wheel, wire rope, chain and upper rudder bearing this year. The serial number was helpful in getting the correct parts. Edison has great tech support.
Dan
