Eating belts
70
Hunter 1994 40.5 Ponce Inlet FL
We motorsailed our "new" 94 40.5 from SC to FL over the 4th July weekend.
Yanmar 4JH2E.
Adjusted the alternator belt beforehand, then daily from there. Replaced after day 2 and still can't get more than a day without excessive dusting.
Alternator is a 129470-77200 (80 amp).
I've put a straight edge across pulleys and the alignment seems perfect.
Checked as close as I can and the groove angle seems consistent across flywheel/pump/alternator.
With belt off, everything free wheels fine.
Adjusting so that i get about 1/2" deflection on longest stretch and about 20 lbs.
I'm at a loss. Only running a refrigerator, no huge load involved.
There has to be something i am missing (as a new dumb owner)
KD3PC
1,069
boatless rainbow Callao, VA
V belts...should be adjusted for about .5" per 12-15" of distance, adjust for longer distances. Not sure what the 20 lbs is, if you are using 20lbs deflection, rather than just pulling with your finger or a gauge, you are likely too tight. Never put your finger or hand under or on the belt when engine is running.
You need to make sure that the belt is riding the two sides of the pulley, not in the bottom. And that both sides of the pulley are rather smooth.
Some of the new (cheaper) belts will dust, but should not be extraordinary. Make sure that the belt is not rubbing something it shouldn't and examine the ruined belt to see where and how it is wearing.
Those things should give you at least a year or better of good service.
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Do you have the stock 55 amp Hitachi alternator or has somebody 'upgraded'?
Original alternator is normally painted at same time and same colour paint as engine.
Apr 12, 2009
101
Hunter 1996 hunter 40.5 Green Cove Springs FL
Yanmar 4JH2E.
I would like to know what happened..I just bought a 40.5 , same power
May 9, 2011
70
It looks stock. It seems painted the same exact color as if from the factory, but it is marked 80 amp and it seems this boat should have come with a 55AMP. Let me know if you are having belt issues, and if not what alternator is on your 96.
Thanks
Dec 2, 1999
15,184
This issue has been addressed before. What type of belt are you using? Are they OEM or some other mfg.
There have been issues that the belts are not the proper "V". I think that the Gates belts are supposed to be good as well as the Yanmar belts.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Think 1/2" is way too much
I think that 1/2' deflection is way too much. Not sure what you mean by the 20 lbs. An 80 amp alternator is approaching the upper limits of a single belt system, so the belt needs to be pretty snug. Also, what kind of belt. If you have a belt that is too wide, or one that is too narrow, will wear pretty fast. The engine and alternator are metric, so you can't just throw any belt on there. I have a 3GM, with a 70 amp Hitachi, and have a pretty constant dusting problem, although don't have to constantly tighten the belt, and it's not severe.
Rick D
Jun 14, 2008
7,193
Gates...
....Green Line if I recall. I have a 90 amp Balmar and used to get some dusting from my stock Yanmar. But since changing to the Gates, much less. Some dusting is normal, especially with a new belt, so not to worry too much. Three or four belts in 2300 hours, and all for maintenance reasons only.
May 9, 2006
56
Beneteau 373 Mystic, CT
RE: Eating Belts:
I have a 3JH4E with a 1/2" nom. belt, driving a Amptech 125 Amp alternator with a Balmar ARS-5-H external regulator to prevent overloading. Initially I used a 1/2 Gates standard belt with poor results. Tried one of the Gates belts with a green woven cover, which dusted terribly and lasted only a few days. Last year went to a Gates gogged belt ([FONT=&quot]NAPA L25 9440) [/FONT]and left the adjustment tension at about 1/2". Belt has lasted 1-1/2 years and only minimal dusting.
May 9, 2011
70
Thanks all.
Using stock belts on 4jh2e
Yanmar 25132-004600 and Mitsuboshi remf-6460
When I said 20lbs it is what i estimated the pressure I applied midway on the largest span to get 1/2 inch deflection. Obviously I'm doing something wrong, but I've been adjusting belts all my life and never had a wear issue like this.
I will check out the cogged belt you mention. Found a wealth of info on this site as well.
http://www.vbelts4less.com/
