Easability of launching the O' Day 25
L
Lindsey
removehtml]Hi I am considering buying an O'Day 25 and was wondering how easy it is to launch at a ramp, or do I need to find a crane to launch? Any information wuld be greatly halpful. ThanksError: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Jan 11, 2007
294
Columbia 28 Sarasota
Lindsay, call me...
Lindsay, email me at ross_in_tampa@yahoo.com I will give you my phone number. I have a trailerable Oday 25. You will have no problems launching it. Ross
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
O'Day 25 launching
I'm assuming that you're thinking of buying an OD 25 keel centerboard sloop. It really depends on the type of trailer you're planning on using and the depth of the ramp that you would launch from. Two of our club members have bunk trailers for their OD 25 and 26 sloops, and they don't seem to have a problem launching at our club ramp at high tide. Most of the OD 25s have a mast raising system that came with the boat, that allows you to raise the mast with the aid of the boom as a Gin Pole, along with a bridle to keep it centered while raising and lowering. The OD 25 is a pretty nice boat for coastal cruising. Joe
Oct 11, 2004
100
Oday 25 O'Day 25, Cutchogue, NY
Ramps are all different
I can't use my ramp at high tide because it starts out with a gradual slope and get steeper further out. I can only use it at low tide. At high tide the truck is in the water before the trailer's fenders even get wet. Therefore, check out your local ramp or ask other local sailors.
Robert Krosse
Kick-up Rudder
Hi Steve Braverman, I noticed that your boat has a kick-up rudder. What make is it and are you happy with the performance? Robert
Jul 24, 2007
21
Oday 23 Lake Erie (Monroe, Michigan)
Kick up Rudder
Robert I have a O'Day 23 which has very simular lines to the 25. Last summer I broke the rudder off just below the lower pintal, which meant I had to make a repair. I'd always found the boat would roll over and round up in a gust and thought I was pulling the rudder out of the water in these conditions. So when I repaired the rudder I extended it 14 inches. I found this made a vast improvement in the boats sailing charateristics. It no longer rounds up excesivly in a puff, I can now hold it down with the helm. The real problem with the old short design was it would stall when to much helm angle was applied. Which was also the root cause of the rudder breakage in the first place. The down side is the rudder now sticks significantly bellow the keel. Therefore I'm now building a kick up rudder that will draw 3'6" when down. I used to race a S2 7.9 Grand Slam which had a dagger board and folding rudder it was a super combination we could get into water as shallow as 18" I think you will be very happy if you can find or build a folding rudder. Clark Teal
Oct 11, 2004
100
Rudder
I got the rudder from Idasailor. It's the same rudder sold on this site. So far I like it a lot. It's a little hard to raise sometimes, but I think they've redesigned the rudder to fix that problem. The price has been raised a bit though. I only paid about $600 for mine. I lost my rudder in a storm and the Idasailor rudder was much cheaper than an oem replacement from D&R.
Jun 2, 2004
1,438
Oday 25 pittsburgh
Steve, Good job, great info ...
The only thing I can contribute is good job Steve! r.w.landau
Tom Smith
While I cannot attest to launching a 25, I have a 1979 23 that I launch all the time. I've never met a ramp I didn't like, and I've even pulled it around with my minivan. OK the 25 is something like 1000# heavier, but it really doesn't take a lot of water to get the stern to float off the trailer. Then I pull it off using a little outboard motor. To retrieve I just sail it in and winch the boat onto the trailer. The tounge of my trailer is pretty long and the axles allow the bottom of the keel to sit about 12" aboe the ground. On most ramps the stern is floating even before my rear tires are wet....others I'm into about 6" of water at the rear tire. Somewhere I have written down all of the lenghts (Axle to hitch, tounge-length, DWL above the road, keel above the road---that sorta stuff) but I can't find it now. Buy it, haul it to a nearby ramp, and get it in the water, if you can get it afloat, you'll get it back out.
