I have an early (pre 1980 I believe) Raritan PH head that I’d like to turn into a PHII. I see that I can buy a PH II Lower Base Assembly for about $300 and use the same bowl which is one option. However, I also noticed that I can buy a complete PHII pump assembly (minus the base) for about $200. Does anyone know if a PHII pump assembly will bolt up to a PH base? Based on the Raritan diagrams it looks like the PHII pump could bolt on to the old base right at the flapper valve assembly but I’m not sure if the bolt spacing or the flapper are the same. The old PH manual lists the flapper at PN 1228 and the PHII lists it as 1228CW. Just for clarification, I’m not talking about the PHC.
