When the dealer's staff were detailing the boat for delivery, they removed the carpet runners they had installed from day one to protect the cabin sole. Underneath they found that the finish on the phenolic flooring was peeling or flaking in a number of areas. Although the fix is rather simple, it will be time consuming given that there is a somewhat lengthy drying time between coats. The reason, I have been told, that the finish is peeling is because something has occurred to prevent it from penetrating properly at the time of application, causing it to dry on the surface. This is to be addressed in the off sailing season.
More to follow.
More to follow.
