Dytek Charger ??
Don Curt
Does anyone have any info on the dytek charger for a 1996 336. I called hunter and they gave me the dytek phone number. Dytek wants a model number. There is no model number on the unit only :Dytek automatic marine charger" I am trying to find out the technical info on voltages, stages, banks, amps, etc.
Don Curt
Got minimal info from Dytek
I have not verified this yet, but Dytek tells me the charger on the 336 (at least my 1996) is probably a GP-12-30 which is a thirty amp charger. It can handle 3 or 4 banks depending on which Hunter put in. It is NOT a multi-stage charger, but is a more common bulk charger good for plain old wet cells. Max voltage apparently goes to 13.8 and float amps in the 5-7 amp range (though this sounds high). They faxed literature, but is not much help. Hope this helps some other 336ers or whomever has a Dytek.
