dynastarter and parts request
Oct 30, 2019
31
Looking for Dynastarter and voltage regulater for my md6 on "Puffin"
#2137 Also seek washboards, dodger, any deck trim in teak. Pat 302
344 2728. Marathon FLorida
Oct 31, 2019
163
Re: Dynastart Regulator - The regulator is also a switch to change the Dynastart between it\'s starting and charging modes. I can\'t comment on the US; but these are definitely still available brand new (from Lucas) in the UK; the bad news is that they cost over £200!
Bob.
SPONSORED LINKS
Boating safety Boating supply Gsi outdoors The great outdoors Albin vega
Nov 8, 2001
1,818
Hi
I can usually a source a secondhand Dynastart Regulator/Solenoid for
about £20. The dynastart is another matter. Heavy and expensive to
repair.....
Cheers
Steve Birch (Technical)
Oct 31, 2019
84
Thanks for response Steve. Would be interested in regulator and any news of a spare dynastarter. Also seeking washboard planks, old style dodger, and plastic vent on stern. Found vender that will make new mainsail here in Florida for 750.00 US. Also have friend who has designed different regulator for MD series and swears it is a much better system. He asked me to research interest and possible sales applications.... Claims it is more efficient and much cheaper than Lucas.... Look forward to further communication. Pat <steve@...> wrote: Hi
repair.....
Cheers
Feb 4, 2001
50
Hello,
My starter generator died last summer. I found that there are
alternatives to the original Bosch pieces. The starter generator used
in some Cub Cadet lawn tractors and the Vire 7 engine are equivalent.
I believe a replacement can be found on Ebay for about $100.00 to
$129.00 from various sellers.
Best of luck.
Antonio Virgini
Frana Vega 1563Starter / Generator
7 May 2004 - From JH, USA - I've found a source here in the US for
the Delco-Remy Starter/Generator, Part Number 1101864. They also have
repair kits which include bearings and brushes. Their address and
phone number is:
Jebco Alternator & Electric Service
609 Main Street
Riverton, NJ 08077
USA
Telephone (from the USA):- (856) 829-7589
Website:- http://stores.ebay.com/JEBCO-STARTERS-and-ALTERNATORS
29 March 2004 - From David Hughes , USA - Some engines are fitted
with separate voltage regulator and starter relay. The Bosch starter
relay that came with my engine was bad. After trying to find an exact
replacement with no success, one mechanic suggested just using any
similar sized and configured starter relay. I ended up using a
starter relay from a Ford Taurus. Apparently, you can actually use
just about any relay.
19 March 2002 - From Mike, USA - The Starter / Generator is Delco
part number 1101864.
Oct 31, 2019
84
Thanks for note Antonio. Are you saying the bolt pattern is the same as the dynastarter?The cub starter generator will fit in place of dynastarter for the md6? Thanks, pat
Antonio Virgini a70virginis@... wrote: Hello,
Best of luck.
Antonio Virgini
phone number is:
609 Main Street
Riverton, NJ 08077
USA
part number 1101864. SPONSORED LINKS
Feb 4, 2001
50
Pat,
When my starter generator died I was about to purchase an alternative
unit. Fortunately, I was able to get Alan of "Voila's" unit from his
md6a. I did, however, speak to a representative of the company that
was selling the Delco unit. He told me that the pieces were
interchangeable. Nevertheless, It may be worth the effort to do a
google search and make a few phone calls as the Bosch is far too
expensive.
Best of luck,
Antonio Virgini
Feb 4, 2001
50
Pat,
I'm almost certain the the Delco Remy 1101864 unit will work.
You can find info regarding the starter generator in the following
pages.
Good Luck
Antonio Virgini
Oct 31, 2019
84
Antonio, Thats great, I will go there online and check it out. Thanks for your consideration, Pat
Pat,
pages.
Good Luck
Antonio Virgini SPONSORED LINKS
Aug 27, 2004
17
Pat,
Last year I sourced an EFEL 06000 dynastarter for my MD6 from an
Italian company ERA SPA. Total cost, including shipping to Scotland
was around 130 Euros.
ERA's email address is: era@...
Cheers
John Buchanan
2253 Houlet
Oct 31, 2019
84
That sounds great John, did you have to make any modifications or did it bolt right on? Thanks, Pat hingumy jrb@... wrote: Pat,
Cheers
John Buchanan
2253 Houlet
Aug 27, 2004
17
Hi Pat,
Apart from enlarging the mounting holes to the same size as the
original, no mods were required. The original pulley fits and the
electrical terminations are identical to the old unit.
Regards
John
