I made two battery boxes for the 4 EGC2 batteries I picked up from SAMs on Monday (seee attached). There is a lower box (mounts in shower sump), and an upper box (mounts on top of lower box). Total hieght is 28 inches. In anticipation for this, I had already remade the cabinet set under the map table. It is two inches longer than before to take the battery box column. I can lower the column further in the sump if need be, but I don't think I will need to if my measurements are right. The trick will be to load the batteries into the boxes since each battery weighs 68 pounds, the pair almost 140 pounds. The lower box should not be an issue putting batteries in the mounted box. The upper will require some rigging I've yet to make to allow sliding it into place. BTW - The steps now mount to the sloping front of the map-table cabinet and lifts out for access to the battery banks.
I still need to drill the holes for the power cables and hydration tubing lines and paint, plus mount the mega fuses for each battery pair, plus the bus bars, but we are getting there.
