1) If you are using the dry bowl function does your raw water seacock need to be open?
2) Should you be able to feel some pressure when you are pumping? I get a couple of pumps with pressure and then it seems not to have any resistance.
3) When I pump, there is a leak from around the base of the pump assembly and around the screws at the top. I put a little silicon sealant on them this morning. Should that do the job?
thx
thx
