I want to install a 12 volt outlet on the side of the coaming near the lazarette for a tiller pilot. My outboard has a 6 amp. charging system that connects to a terminal strip (enclosed in a box)in the lazarette and the battery cables attach to the same strip. I am wondering if I can just tap off the terminal strip in the laz, or should I run new wires from the battery. Seems to me the battery would provide a "buffer" for the charging system...but not sure. Thanks.
