We bought our Hunter 33 this spring and we are generally happy with the boat.One month after we had our boat, the drive coupling separated between the Yanmar engine and the propeller shaft.It was quite a surprise and we were lucky that it happened when we had a lot of sea room to allow us to put the bolts back in again.The Hunter manual's recommendation said "routine inspection of the drive coupling bolts is a must". I asked Hunter to be more specific. Should we be doing it annually, monthly, weekly, daily, or should we stop the boat every hour and check it???The local dealer service recommendation is that we should check it every time we go out.I had a chance to talk to the Hunter factory people last week and they said the Yanmar recommendation is to check it every 50 hours of engine use.Frankly, I am not sure if they relaxed it from every time we go out to 50 hours because it sounded so rediculous or whether they really have good technical information on the 50 hours.I am not sure whether to believe them because it is our life and safety that is at stake.My point to Hunter is that even though this is a tough coupling application with axial and shock loads, they should do better. I don't know of any outboard motor owner that check their propeller lock nut every time they go out or ever and they have the retaining nut in the water and rotating out when in reverse. The auto companies would not dream of asking their car buyers to check their wheel nuts everytime they go out in their cars.I wanted to put some slotted or castle nuts in instead of the regular nuts so that I can wire the nuts to prevent them from unscrewing from the bolt. This is already done with the set screw that holds the half coupling on to the propeller shaft.However, this is not possible because the output shaft of the Yanmar gearbox is so short that there is no clearence for a nut that is a quarter inch longer than the standard one. As it is, putting in a lock washer already resulted in rubbing the rim of the engine drip tray down.The other option is to drill through the nut and bolt and wire through but I can't get the drill in there because of a wiring pipe directly over the coupling blocking access.The factory response is that this is a Yanmar problem. They are sympathatic but I do not get the idea that I will be getting much more help from them on this issue.Are there any other Hunter owners that have this problem? Do you all check your drive couplings religiously? It is a scarry feeling when you expect the engine to work and it doesn't! Think about it next time you are in the marina or fighting the tides or in a storm. Can you count on your drive coupling to stay together?Thanks, Oliver.
