drive coupler
jbaker
Mar 7, 2004
7
- - Juneau Alaska
Have 1979 cat 30 trying to find coupler, Transmission to prop shaft 1" shaft coupler is over all 4 or 5 inchs wide and has bolts with brass and rubber to make conection have not had any luck finding this part. has a small diesel engine. Thanks for any help Jack
C30 Coupler
Try this link and look around their site. Stu http://www.marinedieseldirect.com/universal/200157/
jbaker
Mar 7, 2004
7
- - Juneau Alaska
Coupler
Thanks Stu that was a good tip but they did not talk about couplers except to say the engine must be aligned with coupler and shaft Thanks Jack
More ideas
Have you tried a google search like the link (Hurth transmission)? Also, I know you're way up north, but a call to Torrensen might help. Stu
Another Idea - Drive Coupler
jb Try this: Give Joe Joyce a call at Universal at 508-823-7677 ext. 234. He should be able to tell you the parts you need and direct you to a nearby dealer or service center. Stu
John Olson
couplerTHe coupler is sold by catalina
catalina sells the coupler with the drive shaft shaft four the C30 call them I think they will sell you the coupler.
A
Augie Byllott
Flexible shaft doupling
Check the link below to see whether this is what you're looking for. The graphic shows a wrapper or something across the item. Rest assured that the hole for the shaft lies under it. A search using the keywords "flexible coupling" will probably reveal more sources.
