Mark Gale
The raw water pump on my 21 hp M25 Universal diesel has a steady drip when running from what appears to be a weep hole behind the impeller casing right below the impeller drive shaft. One mechanic says the shaft is worn and needs to be replaced. Another mechanic says this drip is normal and provides lubrication for the shaft. Who's right?The engine has about 900 hours and runs great. It can growl along all day at 2800 with no overheating. Then again, the water coming in from Lake Michigan is usually in the 60s.Thanks, --Mark
