dripless
173
Oday 25 Tampa Bay
The boatyard is hauling my boat out for bottom work, should I have them install a dripless stuffing box at the same time? What are the good and bad points of having one installed? About how much should it cost? thanks, jack
John J
PSS
We have a PSS dripless and had it installed when the boat was new in 2000. So far so good. I check the collar a couple times a year and make sure it is tight, burp it and so far that has been all the maintenance I have performed. The bilge is bone dry, so if I find any water in it I know there is a leak somewhere. Based on my experience I would recommend it. John
Jon W.
May 18, 2004
401
Catalina 310 C310 Seattle Wa
Likewise
Installed new in 2000'. Works perfectly. By all means, install at haulout.
Save a lot of money
and just install dripless goretex from e-mmarine in your existing stuffing box. Why complicate a simple matter? Stu
John
Green stuff from WM
I tryed the green clay stuff from WM with the teflon grease and the synthetic flax .My shaft is grooved and the green stuff works great dry for two years. John
