OK, I KNOW this topic has been discussed to death, but... what the hell, I'm new here
I need to replace the stuffingbox on my Ontario 32 (long story!). Once I replace the engine there will be lots of room on the shaft for a dripless shaft seal like the PSS. But two problems:
1. I'm not sure the larger diameter of the shaft seal will fit (see pic). There is a beam under the stuffingbox that I think USED to actually hold it (hence the need for the flex coupling!). It's now floating, but there is maybe 1/4" clearance under the existing stuffingbox.
2. The stuffingbox is cheaper, and with the new teflon "stuffing" they're pretty much dripless as well.
Another consideration is ease of installation. The actual installation would be easier with the stuffingbox, but I'm not sure I could get the stuffing in "right". How hard is it to do, and how easy is it to screw it up? I've seen writeups of it, and it seems the hardest part is getting the old stuffing out (which of course would not be a problem for me) and having to do it on a stuffingbox already installed.
Comments?
druid
Comments?
druid
