We talked to Hunter and they suggested we replace the bellows. We ordered the repair kit and proceded to take the bellows off. We loosened the clamps on the bellows and the set screws on the collar. It had on set inside and one set inside. We then loosened the bolts and the pin that hold the shaft to the transmission, however, the shaft will not come out. It is stuck in there but good. We have check to make sure we didn't miss any set screws or nut or bolts and have used liquid wrench but it will not budge. Somene suggested we give it a good whack at the end of the prop. We have a folding prop and I am somewhat hesitant to give it a whack.
Any suggestions would be appreciated.
Thanks
Sheila
Thanks
Sheila
