Dripless Packing Coumpound
Hi Brian,I used this dripless coumpound last season and was very satisfied with it. No drips into the bilge. I do have a bronze prop, and am told not to use it with a stainless steel shaft to avoid crevis corrosion.You have to put in a ring of regular flax packing, then crumble up the dripless coumpond and put it in (equivelent volume to a flax ring), then put in one more standard flak ring. You end up with a sandwich of flax-coumpond-flax. Then put the retainer (plastic) and packing nut back on and tighten 'snug'. Dont over tighten. Manually check shaft rotation.I plan to continue to use it. Nice dry bilge.Dick CareyS/V PuffinH-33.5 1990
