Richard Richmond
I noticed that water was collecting in each separate section of my Hunter 25'. It would not pass over the stringers unless it reached about 3.5" deep then it would flow into the next lower section, always accumulating behind the stringers. This was not letting me keep the boat dry and aided mildew to develop. The bilge pump never got a chance to drain all the water from the bilge because of this. I plan on drilling a 7/16" hole through the lowest point of each section's stringer, then cutting a piece of 1/2" outside diameter tubing, coating it with 3M's 5200 Adhesive, and inserting it into the hole. I will then trim it to the edge of the stringer so that bilge water will pass to the lowest point and be pumped out by the bilge pump. I would like to hear from expeienced mariners if they feel this 7/16" hole will weaken the stringer. Should I inject epoxy into the sides of the hole prior to inserting the tube? Any ideas or thoughts would be appreciated.
