Drilling A Hole in H26 Tiller
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
I will be installing a Tiller Mate on my H26. I have to install a small cleat on the tiller. I may be able to install it near enough to the end of the tiller that I can simply use a bolt and nut. BUT, if I can't , I'll have to screw it onto the tiller. Should I tap a hole for the screw or simply use a self-tapping screw? Any advice will be appreciated. Thanks! BrianW
LDM
Mar 21, 2009
71
Hunter 22 North Creek, Bath, NC
I would tap a hole for the screw. Use a drill bit that is just a little smaller than the threads. A self-tapping screw may try to push the laminated layers of wood apart as it goes in and create another problem.
BrianW
Jan 7, 2005
843
H26 Tiller Is Tubular Stainless Steel
I'm sorry I forgot to add more detail..... My tiller is made of tubular stainless steel. BrianW
Tom L
Jun 24, 2004
56
Hunter 23.5 & 29.5 Baltimore, MD
Re: H26 Tiller Is Tubular Stainless Steel
Are you sure it is stainless steel? My H23.5's tiller is made of tubular aluminum. I thought it was stainless until I went to drill two holes to mount a tiller extention and I found out it was aluminum (too soft to be steel). I drilled two holes on the top within about the last 3 inches to mount the extension and used small stainless steel bolts with lock nuts. I taped the nuts to a small wrench and was able to reach in to screw the bolts into them.
BrianW
Jan 7, 2005
843
Thanks Tom for the correction about the aluminum tiller! I verified mine by slightly scratching it with a steel razor knife. Yep, it's aluminum too! That info is really good to know. Thanks again. BrianW
