While inspecting the Drifter for the 2010 season I remembered a trickle of water entering bilge locker 3 the most aft in the cabin under the coverboard.
Initially I had found the compartment full of water in September of 2009 A small hole approximately 1/8" toward the top of the compartment had issued seawater(stained brownish) into the compartment. After the season I had forgotten about it.
Yesterday was a moment of truth. Using a 1/4/ drill I opened up the small hole and with full insertion of the bit noting the presence of water in the flutes of the drill. Proceeding further I tapped an additional hole at the lowest point of the compartment and bailed out by sponge into a bucket about two and a half gallons of water! There is obviously potential space below the cabin bilge compartment areas. There is also the fact that the accumulated water could have been condensate. Drifter is a 1985 23 Hunter.
My plan is the develop an inspection port at the bottom of compartment 2 and verify the status of further existing moisture and possibly irreparable hull damage due to the presence of water there that has gone through a midwestern winter.
Hopefully there was an adequate amount of potential space to handle the expansion of freezing water. Any input re: the above would be appreciated.
