A
Asa Colson
Due to the posts on this forum I checked my compression post for rot. I found that my post was very rotted at the floor. The teak is glued to my post is this what everyone else experienced?There is a reinforced vinyl hose that my wires run through on their way to the deck. I assume that this hose does not create the desired loop above the deck because water appears to have been running down them. I know someone asked what everyone's opinion was about drilling an access hose near the base of the mast to see what was going on with the wires in the mast. No one ever answered whether they felt it would hurt the mast integrity. Are there any opinions about this? I would ask Isomat but they of course are out of business.My boat is in the water and the mast is stepped. I plan to place a supporting jacked post to the port of the compression post. Then pull out the compression post. I will then repair and replace the post.What is everyone's opinion of my plan?I don't know whether the cross member is rotted. How can I tell if it is? The fiberglass encapsulating it is not compressed as it shows in the forum pictures. Will I be able to tell when I pull the post?Thanks for any help.Ace
