I have an '88 Cat 30 Standard Rig (#8510), and during the inspection, the water tanks were filled in order to make sure the waterpump worked and there were no leaks. The inspection did not find any leaks and the water came out nicely from both the double galley sink and from the head sink. However, a couple of months later when I turn any of the water faucets on, the water comes out in spurts. Since having the boat, I have not run the water very much at all, so the tanks should still be quite full. What would cause the uneven spurting out of water?Also, I would like to empty the water tanks. I have two tanks (I believe 40 gallons total). Is there a switch that exists that I need to open to gain access to each of them or will both be drained automatically if I use a hand pump?I look forward to the feedback.Harrison
