Replace the Filter!
TimI have the M-18 and the same Racor setup. If sediment is breaking through the filter that may not be good. Its good preventative maintenance to replace both filters (Racor and the one mounted to the engine). Go to the Universal Marine Diesel Website, search for the M -18, check out fuel filter replacement and you can get instructions and illustrations. Filter is cheap an d comes with a gasket. Its very easy to replace (fuel lever at tank off, bleeder screw on top to release excess pressure, twist off, drain, remove filter and gasket, replace fuel and gasket)......do not stop here........Find the RACOR, use a rubber banded type cannister wrench (any autoparts store), put a bucket or bowl under filter (grab metal filter itself not the clear bowl thats screwed onto the bottom of the filter unit, twist off, let drain in bucket or bowl, remove clear drain unit with another rubber wrench while holding the metal filter with the rubber wrench, and twist off the clear drain unit. Watch where the gasket go on both the metal filter and the bowl. The RACOR replacements are at West Marine. Several gaskets will come with the kits with instuctions. Its a piece of cake to put it all back together. Snug it all down and put it back on. Do not forget to lubricate the gasket on top of the metal filter with fuel oil that will seal against the housing. No different then an auto engine filter. No need to do any bleeding of the RACOR at this point. It will fill up and flow over tot he en gine mounted unit. Now clean up any spilled fuel, open that gas turn off lever, turn the key on WITHOUT STARTING THE ENGINE so that the fuel pump fills the RACOR unit then the engine filter (the bleeder screw must be cracked open on the engine mounted filter to purge air and allow effective bleeding. Once fuel spills out of the bleeder, tighten down. Key off, wait a few minutes, clean up any spillage, and start the engine. You may have to bleed again if it struggles. For safety I had my buddy standing by with a fire extinguisher because of some spilled fuel near the engine. SAFETY FIRST!!!!!. New filters and a wonderful sense of accomplishment. Check out Torrensen (sp) Marine on the web for OEM parts and confirmatory instructions. Good luckBob
