Draining Aft IceBox?
2
Oday 35 Oyster Bay
Hello,
In launching and commissioning my new 35, I can't seam to pump antifreeze (or anything) from he after ice box. The hand pump works fine pulling from the forward box.
Is there a diverter switch I'm not finding somewhere? Or, *gulp* might I have a clogged hose?
Thanks a lot,
Stillman
s/v Scudder, O'Day 35
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
Mine has a "Y" valve under the sink, starboard side. I've always had an issue pulling water from the back icebox. It works but it's much harder to pump. I ended up only using the back box for dry food storage.
Nov 11, 2008
54
Oday 34 Noank, CT
I have a 34 and I think that the setup is the same. I called the PO and he said the aft box drain clogs easily. There is no shut off. I ran a small mechanics "grabber" down the drain and used it like a plumbers snake to open it up.
Can anyone tell me where to get a new hand pump or maybe how to rebuild the one I have? It will pull, but I have to pump like mad to do it.
Jun 2, 2004
297
Oday 35 Staten Island, NY
Pump repair
Heinz,
The Fynspray hand pump for my icebox was doing squat, so I just recently pulled it, disassembled it and found that a key washer had hardened and shrunk, meaning no suction in the pump, no draining of the icebox. I checked on the Imtra website (they market the New Zealand-made Fynspray pump) and found a repair kit available for the unit. Just over 10 bucks plus shipping -- kind of a ripoff for a couple washers and some packing gland material -- but what the hell, at least now I have a working icebox pump.
I don't know what kind of hand pump you have on your O'day, but if it's similar, I'm sure a repair kit if available.
Pete
s/v EmmieLou (O-322)
Little Silver, NJ
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Thanks for the info
My hand pump hasn't worked in about a year so I gave up on it and use a beckson portable hand pump. I just ordered two of the rebuild kits, one to rebuild and one for a spare. A new unit is well over 100 bucks so thanks for the heads up on the source for this.
Dave
Jan 27, 2008
3,086
Fynspray pump rebuild process - Anyone done this?
I picked up the "rebuild kit" and took the top nut off the pump but I can't pull the piston out of the bore? Has anyone rebuilt one of these pumps? Do I need to unscrew it from the counter and disassemble from underneath? Any help will be appreciated. It is probably easier to just drain the ice box into the bilge with a shut off valve, but I don't want a hole or an unworking pump in the galley counter.
Thanks,
Dave
