Although I sail a Beneteau, I'm sure my question is not unique to Benes. Like many, it is time to winterize here and I've done everything except the engine (may get a few more sails in before real freezing weather sets in). I do not use antifreeze in my fresh water system. I blow out the lines instead. This requires me to disconnect and drain the water heater. The way my water heater (a 6 gallon force 10) is located, when I open the drain valve there is no way to fit anything under it to catch the water. It drains into the bowels of the lazzerette and eventually finds it way to the bilge. Not sure of the convoluted path the water takes but it takes days maybe weeks before it all gets to a place where I cam remove it.Does anyone have a better plan?ThanksBill
