Drain plugged
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Put a water hose to it from the anchor locker down. Don't use any harsh chemicals which may not be eco friendly. You may try snaking a wire down but remeber you are dealing with plastic fittings which may be old and britle and the last thing you want is water inside the v-berth.
Dec 2, 1997
8,970
- - LIttle Rock
I'd do the opposite...
Stick an awl, screwdriver blade or whatever fits into the thru-hull from the outside and ream it out. 'Cuz the blockage has to be plugging the thru-hull...and it's a lot easier to accesss from the outside than from the inside of the locker.
