Hey everyone,
On my Cat 22 I just purchased, the drains maybe plugged. Below is a valve were the 2 drain hoses come together then they run into 1 pipe down below. I'm going to check the hoses to see if there clogged but were else does that water run to. Is there another area I need to check. I will make sure the valve on the two drains hoses works while I check the hoses.
